mf65
bill mcintyre
08-22-2006 14:46:24
just aquired a mf65 in bad shape that is not running and i'm trying to get it running. i have two questions; first is the electrical system a positive or negative grounded system, second question is how do you polarize a voltage regulator?
JJ. in B.C.
08-22-2006 19:32:34
 Re: mf65 in reply to bill mcintyre, 08-22-2006 14:46:24
Should be neg. ground. You don't polarize the VR you polarize the Generator. If you go to "search this site" under research & info at the left of this page, type in " polarize a generator" you will find volumes written on the subject. JJ.
DavidP, South Wales
08-24-2006 06:01:35
 Re: mf65 in reply to JJ. in B.C., 08-22-2006 19:32:34
Agreed!
To polarize a dynamo (generator) connect up a live feed from your battery. UK 65's were positive earth. If yours is negative earth, take a lead from the positive battery terminal and with the gen fitted or making good earth hold the lead against the small field coil terminal for two to three seconds. When connected, the ammeter should then show a charge.
DavidP
Eric in IL
08-22-2006 18:04:56
My 65 is negative ground. I can't answer your voltage regulator question.
