Need Advice! MF 275 Fuel Injector
Bratch
09-02-2006 17:13:42
Hi folks,
Fuel injector on my dad's 275 is leaking fuel and I don't know where from (looks to be behind). He says it probably needs rebuilding and wants to get it looked at (good time of year to do so).
Having to close the petcock on the tank to keep it from dripping out.
I ran the tractor myself and didn't notice any problems with it running.
We've either got to boot up $100 to haul it to the shop or try to take off the injector ourselves.
He nor I have ever tackled an injector, are we asking for major problems, or can a couple of "shadetree" guys get this thing off and save ourselves some boot?
Anything in particular to be careful of if we do??
Thanks for any help..sorry about the long post.
TomTX
09-03-2006 01:37:47
 Re: Need Advice! MF 275 Fuel Injector in reply to Bratch, 09-02-2006 17:13:42
You say "the injector". Are you taling about the injection "pump", or a single "injector"? I have the same engine in my MF-690. Do you have manuals for the tractor? Tom
Big Dean
09-02-2006 18:16:10
You remove the two injector hold down bolts remove the bleed off line from the top disconnect the pump to injector line. If everything works like it should it will slip out of the head fairly easy. If the dust seal is bad and crud has built up in the hole between the injector and the head then you will have to pry them up out of the head. I cannot remember if the fuel tank has to be removed on the MF275 or not some tractors it does. Email me if you need more help
Bratch
09-03-2006 06:10:05
 Re: Need Advice! MF 275 Fuel Injector in reply to Big Dean, 09-02-2006 18:16:10
Sorry, I should have been more clear. I meant to say the injector pump itself. Cav model - didn"t get the model#. I just found a post Injector pump -CAV - MF 274-4 could it be shut-off control?
I may be able to get over there tomorrow, clean it up a little, and run it to see if I can better tell where the fuel"s coming from.
In the mean time - if you have any advice let me know, - I"ll post again tomorrow if I can narrow it down.
Thanks for the resposne.
One of my biggest concern taking the pump off is what kind of mess I"m getting into on the driven-gear side..
