Need Advice on MF275 Injector Pump Leaking
Bratch
09-04-2006 13:44:11
I posted a few days ago on this. Took some advice from you guys and it looks like the injector pump is leaking around the linkage "stud" for the throttle cable AND the "stud" for the shut-off cable where they enter the top of the pump.
The nuts on top of the linkage weren't even hand tight on either one. I tightened them slightly which seemed to help the throttle one, but the shut-off still leaks quite a bit.
Are there O-rings or something that can be changed fairly easily?
Bratch
09-05-2006 09:09:47
 Re: Need Advice on MF275 Injector Pump Leaking in reply to Bratch, 09-04-2006 13:44:11
I think I found the post. Thanks for the help.
make mine a massey
09-05-2006 08:23:55
Got the same problem with a 274, chase down to my post for solution, Parts are around 11 bucks Cdn. easy enough fix IF you're careful, need more than 2 hands to do it.
J Schwiebert
09-04-2006 14:44:54
Yes there are O-rings on those two shafts. This was discussed before. Also see my reply to 806 on the Ford form. J.
