Tractormeter
bill
08-05-2000 16:10:04
I bought a mf 50 recently with a serial #535737. The tractormeter was disconnected and I cannot find a place to reconnect it. From the length of the cable it appears to connect to the back of the generator but there's no way. I contacted the previous owner and he says the generator is original. where does it go? p.s. the tractor is a gasoline model and none of the service manuals I have show a connection.
Dave
08-08-2000 22:18:00
 Re: tractormeter in reply to bill, 08-05-2000 16:10:04
I have a 180 Massey. The tachometer runs off the back of the generator. It uses a special generator that has an extended shaft and a special gearbox that the tachometer cable hooks into. There is also a conversion unit to change the generator to an alternator. talk to an AC Delco distributer for the proper changeover unit.
george T
08-06-2000 22:21:41
My 175 alternater has this same set up if you want to switch to 12volt you should be abbel to use this alternator and connect it right up. just a thought good luck. ps make shure you disconect battery before you change any thing I didnt and I did some wire damage. old saying the faster I go the behinder I get. holds true good luck
Paul in NM
08-05-2000 17:14:07
bill - on the MF 50 the tractor meter is run off the rear of the 12v generator. The end plate of the generator comes off and a tach drive unit is attached to the generator. Your generator may be a replacement unit. If you need a tach drive, I may be able to help you locate one. E-mail me if you are interested.
Paul
ed
08-07-2000 11:10:28
 Re: Re: tractormeter in reply to Paul in NM, 08-05-2000 17:14:07
I have the exact same tractor and problem. Mine has been converted over, do you have a universal tach drive?
