mf 50 indust front end
BUTCHTN
09-18-2006 04:34:05
my mf 150 indust on the front end where the spindle goes thru the axle extenion when i put the bucket down and raise the fround ent off of the ground there seams to be a lot of slop between the top of the spindle and the bottom about 3/4 of an inch or more is this normal or is there some bushings or bearing wore out
thanks
butch
Big Dean
09-18-2006 07:31:26
 Re: mf 50 indust front end in reply to BUTCHTN, 09-18-2006 04:34:05
There are thrust bearings that go in the bottom of the axle that the bottom of spindles set against it is fairly common for those to come apart and piece of them fall out. That is probably what is causing your problem. If it has not been run to long like that you can remove what is left of the thrust bearing usually it is just the shell of the bearing left. Replace it with new thrust bearing. If you need the part number and a parts break down of the front axle for it email me
