Oil leak and stop-leak
Bart.CA
09-21-2006 08:56:05
Hi
My MF-50 (no multi-power) is dripping transmission oil by the weep hole. Just began to drip few days ago.
No time to repair it for now...manure to load and
grain to transport. How about "stop leak" sold
at auto parts that they put in truck and car transmission and/or differential to stop leaks.
Thanks for reading
Bart
supergrumpy
09-21-2006 09:37:20
 Re: Oil leak and stop-leak in reply to Bart.CA, 09-21-2006 08:56:05
I have used "Trans-X" in blue can at NAPA to stop very slow automatic transmission leak where the car wasn't worth a transmission rebuild, it softens the seal, it worked for what I needed
would have to use a lot compared to the much smaller amount in an automotive transmission
can might say if it was compatible with tractor type fluid, also would have to toss the oil when actual repair was made
old
09-21-2006 09:21:02
Only thing I have found that type of stuff good for was to mess something up even worse then it was. Tried the stuff in a car engine I had and it caused the oil pump relief valve to lock closed and then it started to blow oil filter O-rings, ended up costing me a few 100$$ to get it fixed
Bill of TN
09-21-2006 19:26:14
 Re: Oil leak and stop-leak in reply to old, 09-21-2006 09:21:02
I've tried several products in the past and haven't had much luck with any of them.
It's cheap so what the heck..... go for it....
