Marvel Schebler TSX 882 Rebuild
Charles wilson
09-26-2006 06:30:38
Yep, got carburetor trouble will not stop pouring gas. I order the kit along with a new float. Now need all advice I can find before I dive off into the unkown. Like how to go about rebuilding a carburetor, what needs to be removed and what needs to be left alone. all help appreciated
old
09-26-2006 09:29:25
 Re: Marvel Schebler TSX 882 Rebuild in reply to Charles wilson, 09-26-2006 06:30:38
One thing you will need is a Gallion can of carb cleaner to soak the carb in for about 24 hours. A good can of it will have a basket in it so you can get the parts back out easy. Also a couple cans os spray carb cleaner to spray out passages so you know there open. Also some small wire helps. Other then that follow the instructions that come in the kit
Charles wilson
09-26-2006 09:45:26
 Re: Marvel Schebler TSX 882 Rebuild in reply to old, 09-26-2006 09:29:25
Appreciate the advice Carb. is soaking as I type, contacted a mechanic friend of mine, he said he would be happy to put kit in carb., so I plan on a big cook-out/carb.rebuild for saturday evening. appreciate the reply
