Z-134...Z-145 Parts interchangeability
Bart.CA
09-26-2006 16:18:02
What is the difference between Z-134 and Z-145
Is it the same block ?
Is it the same head ?
Which parts are different ?
I plan to buy a parts tractor and wd like to know
difference to be sure to have many spare parts.
I have a MF-135 and looking a MF-50 for parts
Thanks for reading
Bart.CA
Badly Bent
09-28-2006 03:58:12
 Re: Z-134...Z-145 Parts interchangeability in reply to Bart.CA, 09-26-2006 16:18:02
Other than the possibility of a few engine parts nothing else from the 50 will interchange with the 135. I agree with Gerald that you're better off working on the 135 with replacement parts. Tim
Gerald J.
09-26-2006 19:21:17
The main differences between the 134 and 145 are displacement made by a difference in stroke and sleeve bore. The head on my MF-135 with Z145 says Z-134. But the parts book shows different part numbers for most everything for Z134 vs Z145 (135 special vs deluxe) from block to head as I remember looking a few months ago. I don't know how close the MF-50 might be.
Unless your 135 is already ill or you plan to run it 15,000 hours in 5 years, I don't think a parts tractor will prove to be a good investment. Most all the wear parts are available new from many sources.
Gerald J.
