MF 65 Brake Dragging
Bob
08-11-2000 06:09:30
My 65 has begun to drag the RH rear wheel upon start up. It is barely noticeable in reverse, but quite pronounced in forward gears. It works itself out after a bit of running, but is there again as soon as it sits for a while. It is often accompanied by loud squealing when it first starts to move. I'm assuming this is brake related, as it doesn't happen in reverse. The planetary oil on that side is right up.
Any ideas you can give me will be most appreciated.
Jack in NB
08-12-2000 04:06:11
 Re: MF 65 Brake Dragging in reply to Bob, 08-11-2000 06:09:30
Hi Bob -
Probably is brake.
There is a lock nut, or double nut, on the actuator rod going into the axle. 11/16" on ours. Back it(them) off 3 or flats - if it is brake, that makes a big difference.
Matt
08-26-2000 18:09:45
 Re: Re: MF 65 Brake Dragging in reply to Jack in NB, 08-12-2000 04:06:11
We had this same problem on the 65 we had. We found out the axle seal needed to be replaced. We had this done to both axles and had no other problems afterwards.
