SPIN OUT RIM
chad9999
10-08-2006 20:13:00
HAVE A 50 MASSY THE BACK RIM IS ATE UP WITH RUST THEY ARE SPIN OUT RIMS TO DO SO JUST LOOSEN THE CLAMPS AND USE THE TRACTOR POWER TO ADJUST I WAS WONDERING WHAT THE NAME OF THIS TYPE WHEEL AND WERE TO GET IT
phil(va)
10-09-2006 19:51:31
 Re: SPIN OUT RIM in reply to chad9999, 10-08-2006 20:13:00
As Dean says, these are available new for about $300. Usually you can get them through your local tractor tire dealer, and that is handy since he can mount the tires, etc. I find that buying from a third party does not save me any money and is more aggravating. A regular rim is about $120, so as you can see, you could buy two non spin-out rims and replace them both for less than one spin-out, which might be an option for you to consider, especially if the other rim looks bad too.
Dean
10-09-2006 01:34:00
Chad:
These are commonly called power-adjust rims. MF used the 4-rail type, and these are readily available new. Cost is around $300 each.
Dean
