MH44 RH Spindle Nut
Bill Marko
10-11-2006 03:18:28
I'm looking for a RH spindle and nut for a 1955 MH 44.
Harris Guy
10-12-2006 12:59:50
 Re: MH44 RH Spindle Nut in reply to Bill Marko, 10-11-2006 03:18:28
Bill, If you need it yesterday, a dilemma. I know that I
have a few in some coffee cans. Probably be a week to get it to you. If good enough, post some number or eddy. In the lower 48(here), I'd simply
send it to a MH 44 owner. Let me know.
Harris Guy
10-13-2006 11:24:12
 Re: MH44 RH Spindle Nut in reply to Harris Guy, 10-12-2006 12:59:50
Bill,
I found the slotted Hex nut, assume you want for
7/8 thread, requires 1 1/4" socket, to tighten. If correct, simply attempt e mail here, I'll send
it, if the proper one. Let me know. Good luck.
Bill Marko
10-16-2006 09:27:56
 Re: MH44 RH Spindle Nut in reply to Harris Guy, 10-13-2006 11:24:12
Mr. Guy, I'm not sure what the outside diameter of the nut is, but the threads are 1 1/8" -12.
Harris Guy
10-16-2006 11:29:28
 Re: MH44 RH Spindle Nut in reply to Bill Marko, 10-16-2006 09:27:56
Bill,
Thought you wanted the narrow front, dual wheel,
spindle fork hub slotted Hex nut. I don't have the larger WFE spindle nut. 1 1/16-12, some 1 1/8-
12, pulley, pinion shaft, but slotted Hex, and a
1/16 larger. Oliver/White had WFE bolts that appeared similar, Super 77,770,possible source? Good luck.
