MF-50 battery charging system
Bart CA
10-16-2006 19:28:56
HI
MF-50 with original 12V generator system.
The system begins to charge at 1100~1200 RPM
when the battery is partialy discharged it will
charge at 20 amp at 1200 RPM and up.
Originaly at what RPM is it supposed to begin to charge ?
I want to keep the generator system in order to have the tach/hour meter system which is driven by the generator.
Thanks in advance
Bart CA
Gerald J.
10-17-2006 04:01:17
 Re: MF-50 battery charging system in reply to Bart CA, 10-16-2006 19:28:56
Sounds about right for the minimum charging speed for the generator, not far from how my MF-135 with generator works.
Does the current taper down to zero after a while? If so its perfect.
Gerald J.
