front wheel problems on MF65 dieselmatic
BM Horse
10-19-2006 18:36:22
I had the RH spindle break recently and ordered a replacement. It is a low clearance with a 11.625" tall shaft(the OD of the shaft is 1.25"), I noticed the bushings are worn badly and would like to know if replacement bushings and thrust bearings can be purchased at a bearing supplier? I also notice the front tire is sitting at a slant, as if it is not fully seated on the spindle, has anyone seen a problem like this, and what would be the fix?
smokey2
10-19-2006 20:35:48
 Re: front wheel problems on MF65 dieselmatic in reply to BM Horse, 10-19-2006 18:36:22
Thrust bearing seems to be a common replacement. Best place to go for replacements is one of the generic tractor parts dealers such as this site. If they cannot help you try bareco. The bushes need to be reamed after fitting.
