Massey Feguson TO35 tractor
Art2
10-23-2006 06:42:57
I recently bought a MF TO35 at an auction. When I got home, I checked the glow plugs and one was burned out, none were hooked up. I connected them to the 12 volt system with a push button switch. I ended up burning them all up. These are very expensive as you know. What do I need to do to make sure that this does not happen again? Is there and aftermarket air intake heater that can be used instead of glow plugs? Also, who is the maker of this four cylinder diesel engine?
Thanks,
Art2
woodache
10-23-2006 12:46:52
 Hard Starting !Re: Massey Feguson TO35 tractor in reply to Art2, 10-23-2006 06:42:57
This engine is made by Standard Engines England. It may be the hardest starting diesel engine EVER made. Without the glow plugs you may never beable to get it started unless it is 110* outside. I dont think any manifold glow plug will help on this engine.
CENTAUR
10-23-2006 14:04:07
 Re: Hard Starting !Re: Massey Feguson TO35 tractor in reply to woodache, 10-23-2006 12:46:52
I do not know anything about your STANDARD DIESEL ENGINE.I did however read your question.Are those glowplugs supposed to be in series or parallel.CENTAUR
