Hydraulic Lift model 130
billy young
08-15-2000 14:44:17
I have model 130 massey diesel. The lift won't lift up all the way now. I've changed the oil and cleaned the screen. Is there an adjustment of the lift height on this tractor?
donald l williams
07-08-2003 21:56:54
 Re: Hydraulic Lift model 130 in reply to billy young, 08-15-2000 14:44:17
in response to your old post on lift model 130.out of book...control spring adjustment the stop bracket which limits the movement of the control spring is attached to thelift cover by two bolts. with the control spring in its neutral position, there should be a clearance of 3/16 in. between the tip of the spring and the rear face of the stop. this clearance is obtained by shims between the housing and the stop. shims are supplied in two thicknesses, .040 in. and .060..... .u can find futher info in your public libary., also i own a 130
