crank pulley bolt torque
Chris GA
10-24-2006 17:14:46
Putting my AD4-203 back together, cant find the torque spec for front crank pulley bolt. It had been running loose due to hyd pump drive plate bolted to it. Thanks for you info. Chris
Barry_ID
10-27-2006 20:19:41
 Re: crank pulley bolt torque in reply to Chris GA, 10-24-2006 17:14:46
When I put mine back on, it was the reverse of removal - big socket on a breaker bar, whack it with a 4x4 about 30" long...not sure what that equals in ft./lbs. I don't have my owners manual handy...sorry.
Aaron Ford
10-25-2006 13:34:08
My manual says to install the crankshaft pulley and secure it with it's setscrew and washer. I do not have this engine so I cannot comment on the accuracy or provide insight. Aaron
135 fan
10-25-2006 20:06:40
 Re: crank pulley bolt torque in reply to Aaron Ford, 10-25-2006 13:34:08
I would think to put it as tight as you can [within reason] with the proper socket size and no cheater. Big Dean would know how tight to put it. I'm not sure if it's good to put locktite on it or not. I know most shops turn the engine with the bolt when setting valves etc.. Dave
