will a 55 diesel starter work on a gas engine
C.R.B.
10-26-2006 04:07:51
will a diesel starter work on a gas engine
massey333
10-27-2006 08:36:33
 Re: will a 55 diesel starter work on a gas engine in reply to C.R.B., 10-26-2006 04:07:51
Yes,it should work because the engine,Flywheel,Clutch Housing are the same.They are a Different starter because the gas is 6 volt and the Diesel is 12 volt.The only thing you would have to change would be to go to a 12Volt system if you are still 6 Volt.
TomTX
10-26-2006 08:47:35
Get the number of the starter in your MF parts manual, then call MF dealer parts man and have him look up the part number of the other model's starter. Tom
