O.T. Massey 6290 (electrical problem)
Bill in Colo
10-31-2006 18:48:34
I know this site is normally for older tractors but I need help, Tractor has about 1100 hour on it and discharges the batteries in about four or five days even with the key removed. batteries were new in July.If this were a chore tractor it would be no problem as when using daily no noticable problem. could the problem be with the alternator?
Aaron Ford
10-31-2006 20:05:10
 Re: O.T. Massey 6290 (electrical problem) in reply to Bill in Colo, 10-31-2006 18:48:34
Not totally sure about the model, but an old trick is to place a low wattage bulb in between the ground post and ground terminal. If you have a drain, the bulb should light. Now disconnect stuff til it goes out. HTH Aaron
