I am the proud owner of a 1966 MF 135 Deluxe, with the Continental Z-145 engine, 3x2 transmission (no multi-power), with the 100 loader on it.My problem is the clutch ( it's the 2 stage job ). It's frozen. Solid. I can stand on the pedal. She no move. Well, it moves the 3/4 inch freeplay, so the shaft into the bell housing is free. I pulled the acess plate off the bottom..... got a small amount of water, a little oil,....and a lot of MOUSE NEST, made from leaves!!!!! !!! The only way I can see that the little bugger got in there is through the timing hole on the front. I'm going to tap threads in it and plug it tight. So, am I correct in thinking I'm going to have to split the tractor to get it freed up ? I figure it's either jammed up tight at the throwout bearing, either with rust, or mouse nest, or mouse guts (serve it right!). Or, it's in the pressure plate. Correct ? Any suggestions to try before splitting? I don't want to get it stuck in, and not release again, because at least now, it will move under it's own power. What is the best way to remove the loader ? Also, while I'm in there, I plan on replacing the disc for the trans, the throwout bearing, and the pilot bearing. Any seals, or anything else, you recommend ? I have E-mailed Big Dean, but have not heard back yet. Thank you in advance, Bill
