Mf35 starter leaking gear oil??
brian
08-20-2000 18:18:08
My starter leaks gear oil from the bottom. Is there a seal at the drive end to keep gear oil
from getting into it? Haven't had time to remove it yet. also- what brand of hydraulic oil should I use?
would a premium universal hyd. oil work ok?
stanley carter
08-21-2000 09:19:08
 Re: mf35 starter leaking gear oil?? in reply to brian, 08-20-2000 18:18:08
Your problem probably is that your weep hole on the bottom below your fly wheel is stopped up with dirt or something.As far as the oil to use.....it all depends.Check the specks.
