Massey 55 GS
Brad123
11-21-2006 13:38:54
I bought 50 something Massey 55 gas. It ran great until I operated it a few times then it started starving for fuel. Took the carb apart and cleaned. Ran good again for a while then started starving again. Any suggestions?
Brad
Ian Johnsen
11-22-2006 20:06:12
 Re: Massey 55 GS in reply to Brad123, 11-21-2006 13:38:54
It may seem basic, but try running with the gas cap loose or off. I have seen tractors cut out from poor gas tank ventilation. You can't take gas out if air doesn't replace it.
Brad 123
11-26-2006 07:37:09
 Re: Massey 55 GS in reply to Ian Johnsen, 11-22-2006 20:06:12
Thanks I"ll try that first before emptying the tank.
Ken from Ontario
11-21-2006 16:17:25
Disconnect your fuel line at the sediment
bowl and remove the sediment bowl assembly
from your fuel tank. Suspect there is a clog
at the screen surrounding the stand pipe, therefore not allowing enough fuel thru to the
carb to meet the requirements of the engine
brad123
11-21-2006 16:59:41
 Re: Massey 55 GS in reply to Ken from Ontario, 11-21-2006 16:17:25
Thanks Ken, i"ll drain the tank while I"m at it.
