Will a hydraulic pump from a 44 bolt up to a 33 ?????
Alberta Mike
08-23-2000 06:19:54
I've asked this question before and got some answers, but none were of the 'for sure' variety so I'm trying again. I've got a 333 (33) and can pick up a pump and housing from a 44. The pumps look identical and the physical size of the housing is the same, at least as well as I can measure them with a tape measure (sort of an awkward measurement for bolt locations). I don't really want to buy it if it won't work. That would also have to be the proper gear alignment inside on the cam gear right? If you know that it will (or won't) work for sure, I'd appreciate your help. Thanks.
Mike
dan diebel
09-26-2000 18:09:33
 Re: Will a hydraulic pump from a 44 bolt up to a 33 ????? in reply to Alberta Mike, 08-23-2000 06:19:54
