Cheap fix
Brad123
11-26-2006 07:44:52
I had a hydraulic cylinder on my front end loader that was bypassing real bad. Pumping oil out of the seal. Tore it down only to find there is a realy old cup style packing. This packing was impossible to find. At the parts store I met a machinist. He said that he would cut be some grooves in the block that the packing was bolted to so I could install O-rings. It worked perfectly and only cost me 20 bucks. If the o-rings go out after a while it will be a $1.00 repair.
Crem
11-26-2006 20:19:46
 Re: Cheap fix in reply to Brad123, 11-26-2006 07:44:52
Good idea. Thanks for passing on the tip.
