MF65 G176 Thermostat Solved?
Aaron Ford
12-13-2006 17:06:16
I stopped by my local auto parts store today and presented my thermostat. It drew gapes and stares cause apparently no one had ever seen a bellows style thermostat. The parts guy drew out a vernier caliper and measured mine. He then produced a 13006 160* Stant new style thermostat. I compared it to mine and noted that it did not have the 1/16" hole drilled through near the flange. I remedied this and installed it. Currently I have nothing to bolt a radiator to so I cannot test it. As far as bolting up, it looks fine.
I was tempted to go to the 180* model, but did not because I do not know why a 160* was used originally. Any ideas?
Let's go Mountaineers,
Aaron
traper
12-14-2006 16:53:08
 Re: MF65 G176 Thermostat Solved? in reply to Aaron Ford, 12-13-2006 17:06:16
You might run better with hotter stat.Reason for 160 stat was to keep non perm antifreeze from boiling away.Seen many bellows stats in my early years
