Massey Ferguson lift problem
Ardie Dedrickso
12-18-2006 16:31:18
I have a Massey Ferguson 35, 1955 with live hydralics. To start out the lift arms would go up and down, but it would not lift a load. I took the lift cover off and put in new gaskets, piston rings and O rings. After doing this it works well and will hold a load. The problem is when the lever is in raise position it lowers the load and when the lever is lower position it raises the load. It has a Draft control lever. Hydralic pump is in good working condition. What is my problem? Thanks for your help.
Aaron Ford
12-20-2006 20:36:45
 Re: Massey Ferguson lift problem in reply to Ardie Dedrickson, 12-18-2006 16:31:18
Manual is located at www dot photobucket dot com Type aaronford1 in the search box.
Let's go Mountaineers,
Aaron
Aaron Ford
12-19-2006 07:40:34
The manual suggests that if the implement raises when lever is moved to the bottom stop the problem may be that the valve adjusting nut is too tight. This is the nut that locates the pivot of the control valve actuator. If you would like a copy of this section of the manual email me. HTH
Aaron
Ardie
12-20-2006 16:21:17
 Re: Massey Ferguson lift problem in reply to Aaron Ford, 12-19-2006 07:40:34
Aron,
If you could send that to me I would appreciate it.
Thanks A Lot
Ardie
