HELP!!! LIFT WOULDN'T GO DOWN
CHRIS-MF35
08-27-2000 17:47:16
while using my blade the lift would not go down. refured to manaul and feared the worst. took top off tractor and found draft control rod coroded, to my releif, don,t have to pull the pump. tried to remove the master control spring retainer nut, boot long gone and rust set in, got the set screw out the side ,with help of pb blaster, but connot get the large internal nut off. anyone know of a way to remove it? thanks for any help.
Whiskers
08-28-2000 13:13:42
 Re: HELP!!! LIFT WOULDN'T GO DOWN in reply to CHRIS-MF35, 08-27-2000 17:47:16
Had the same problem with a MF 50. It should be the same lift. After removing the trans cover the third time in about as many years, I simply removed the accuating rod. This disabled the draft control which I rarely used anyway. I had completely removed the rod, cleaned and greased the rod and housing. It still stuck after a short period. Hope this helps.
