Massey 44 Power Steering
Charles TX
01-01-2007 10:51:43
I"m replacing aftermarket Massey Harris 44 Eaton power steering pump. Replacement pump (junkyard) has a separate reservoir. Can"t find a good mounting spot for the reservoir. Question, has anyone used the radiator monunt hydralic tank to run both lift and power steering pumps. Looks like I could split the flow to run both. Not sure if the lift pump would still properly work with reduced flow.
marlowe
01-01-2007 11:54:02
 Re: Massey 44 Power Steering in reply to Charles TX, 01-01-2007 10:51:43
on the 444 they used one feed outlet but why not put another outlet and inlet on the tank to just be sure we did that when we ran another pump on one just used some 1/2in pipe pungs and brassed them on been on for years
