remotes
Bobby Pollard
01-09-2007 11:06:50
I have a 165 massey,it don"t have any remotes.Is there a kit you can purchase to put remotes on this tractor?Bobby Pollard.
Dean
01-10-2007 15:46:51
 Re: remotes in reply to Bobby Pollard, 01-09-2007 11:06:50
Hi, Bobby.
Yes. You can install a remote valve in place of the cover under the seat that allows control of one or two remote cylinders.
I do not believe that these valves are available new from MF anymore, but they can be found used. Salvage yards and even dealers often have used valves for these tractors.
Dean
GaryF
01-10-2007 18:26:11
 Re: remotes in reply to Dean, 01-10-2007 15:46:51
They are frequently for sale on EBAY, prices are all over the map mostly depending on how complex 1,2 or 3 valves
Gary
Bobby Pollard
01-11-2007 10:43:10
 Re: remotes in reply to GaryF, 01-10-2007 18:26:11
Hey,thanks gary and dean.Now tell me,i'm going to buy an easey loader on it.I'm buying the kit,are these reliable,and should i spend alittle more money,and put a front punp on it also?I have one of the clenest 165's in the country.It has the multipower,but it works perfect.Thanks again,will be waiting for your reply.Bobby Pollard.
Gerald J.
01-11-2007 15:53:46
 Re: remotes in reply to Bobby Pollard, 01-11-2007 10:43:10
Unless the 165 has a much larger pump inside than my MF-135 you'll prefer the front pump. And you can run auxiliary hydraulics with extra valves on the independent loader system with ease.
Gerald J.
