Checking compression on AD3-152
Bart C.A.
01-14-2007 12:48:00
Hi
I'm wondering....
Gas AG3-152 engine 7.5 to 1 compression rate = 150 PSI (stated in service manual)
Diesel AD3-152 18.5 to 1 compression rate = ? PSI (Not stated in service manual)
Should we attempt to measure compression on a diesel engine with a gas engine compression tester ? ...will it explode and cause injuries ?
When starting a diesel engine how many PSI are required to ignite fuel in combustion chamber @ 70ºF (21ºC) ?
Thanks in advance
Bert
richard in nz
01-14-2007 23:20:13
 Re: Checking compression on AD3-152 in reply to Bart C.A., 01-14-2007 12:48:00
A petrol engine compression tester will be damaged if used on a diesel. Diesel will run on about 300 psi, up towards 500 would be ideal. Look for readings to be within 10 to 15% of each other, that is the most important thing to look for. Perkins said on thier training courses for oil cnsumption to be no more than 1% of fuel consumption before overhaul is requred.
Bart C.A.
01-15-2007 08:55:13
 Re: Checking compression on AD3-152 in reply to richard in nz, 01-14-2007 23:20:13
Thanks Richard for the infos
Greatly appreciated !
Bart
