MF3165 power steering pump
CHRIS GA.
01-15-2007 15:14:06
Hey guys, I have PS pump seal that had came out of the seal housing. I disassembled pump and inspected, wear plates,bushings,and shaft all look to have no wear. Upon reading the tech manual I find that it says the seal is to be staked in three places after pressing the seal into the housing. Also after looking at the enternals of the pump,I find there is a drain hole just inside the seal area that returns shaft oil back to the resevoir. My question to you all is the resevior vented in some way, because I can"t find any, the fill plug is solid with an oring seal. Thanks for your time, Chris
