MF Cranking
2Rusty
01-25-2007 06:07:21
My MF 271 will not turn over. Batt. is strong all gauges light up but will not spin/click ect.... Is there a safety switch somewhere that could be suspect????
DavidP, South Wales
01-25-2007 09:36:59
 Re: MF Cranking in reply to 2Rusty, 01-25-2007 06:07:21
Hi, the 271 is not available in the UK but if it follows normal MF design you should see two wires going down to a switch on the top of the gearbox just behind the RHS of the engine. look for a loose wire to start. If both are attached pull them off and join them together with a piece of wire. Check you starting. Don't let anyone else drive the tractor unless they know about this. If this is your problem get a new switch as soon as possible.
DavidP
