Massey Ferguson 65
Bob Pete
01-28-2007 22:25:23
Dual clutch doesn't work to disengage PTO.
I assumed everything was calibrated when I bought a complete new clutch assembly. I, also put in new release bearing. Set up the relaese bearing clearance and reassembled the tractor.
Adjusted clutch petal free end play to 1/8 in. by using the clamp bolt on the release shaft arm and then did the linkage adjustment to 1 in. Checked clearance on secondary pressure plate (from inspectin hole). It was 0.119 inches. I set it to 0.90 inches as specified in the book.
Still doesn't work and you have to literly stand on the clutch petal to push it down all the way.
I really don't want to split the tractor and pull the clutch.
HELP --- I need someones expertise to figure out the problem.
Bill Brox
01-31-2007 04:04:40
 Re: Massey Ferguson 65 in reply to Bob Pete, 01-28-2007 22:25:23
My head is spinning some more here.
From what I can see, understand, and remember, the first stage press the springs, and the second stage press the belleville spring.
This means if you have too many springs on your clutch you shall feel the first stage is getting harder, or easier to press if too few springs.
If I understand you correct it is the second stage you feel is very hard, and that leads me to think there is something binding / blocking somewhere.... like a transport lock or something.
Just a thought.
Bill
Bob Pete
02-01-2007 18:34:37
 Re: Massey Ferguson 65 in reply to Bill Brox, 01-31-2007 04:04:40
I removed the 3 bolts that locked the clutch together after installating it on the flywheel and lining up the clutch discs.
Bill Brox
01-31-2007 03:57:13
Hi there.
MY MF manual, 819 121 M1 says 12 springs on a MF 65 with the A4-192 diesel engine.
This may not be correct if you get a clutch from an after marked supplier.
But the number of springs have nothing to do with your problem, that is adjustment and wear.
The number of springs only makes the pedal harder or easier to press down. And, of course, too few springs may cause the clutch to slip during heavy loads.
Hm... I am still thinking. My cousins MF 165 is exptremely hard on the pedal, prolly too many springs there. But, everything still works normally.
Now I come to think that I have seen clutch assemblies come with some sort of transport locks. May this be the problem, that there is a transport lock in there you never saw or knew about that blocks the secondary stage ?
Just a thought...
Bill
Bob Pete
02-01-2007 18:49:40
 Re: Massey Ferguson 65 in reply to Bill Brox, 01-31-2007 03:57:13
Bill,
The MF 65 has a 4 clyinder 50 HP gas engine and the clutch was new with a new clutch plate and release brg.
See other reply on locks.
Bob
jrsn
01-30-2007 16:06:42
MF35, 135, 148, 240, 245, 250 Use 6 Springs
MF65, 165, 265, 275, 355 Use 9 Springs
MF360, 365, 375, 565, 575, 675 Use 9 Springs
MF175, 285, 290, 390, 690 12 Springs
this is on their Clutch page fo Massey.
quote from BARECO.com -- parts supplier they have nice pictures of all the parts , but no pricing. ray-s
jrsn
01-30-2007 13:09:51
Link
this problem was addressed ayear or so ago. Go to search bar up top and type in "hard clutch" you should get to a list of threads. Go to #143 clutch problem with 135. about page 5 or6. There is talk there of too many springs and how to take some out. ray-s
TomTX
01-29-2007 06:34:18
My MF is too far off in model and has independent PTO, so my manuals can't help. Did you follow the details of the MF Repair Manual?
Bob Pete
01-29-2007 21:10:18
 Re: Massey Ferguson 65 in reply to TomTX, 01-29-2007 06:34:18
Yes I followed the manual, but I assumed the clutch was all set up when I bought a complete rebuilt unit and installed it .
DavidP, South Wales
01-29-2007 01:35:13
Hello Bob,
First of all nothing is adjusted when you fit a replacement unit. Adjustments might be close but you cannot rely on them. Although the distance between the flywheel ledge and face should be the 'same', differences do occur. With the 65's in particular with the rear pivot clutch pedal wear in the bush will lose a lot of movement or you will have a very high pedal. A clearance of up to 1/4" would be better at the point where the arm meets the casing. Did you adjust the position of the lever screws? A general guide is to have the screws just in the depth of the lever, but you will have to accurately measure the height from the face of the plate centre. Having them all the same is more important than the exact height. I suspect that this may be your problem. Perhaps the PTO pressure plate is only being lifted clear on two sides not three.
Having to apply anything more than comfortable pressure is not acceptable. Observe the operation of the clutch from underneath with a torch while someone presses the pedal. Is there any sign of the spring coils touching? If so the main plate is probably being released but there is not enough travel left to accommodate the release of the PTO plate. How many coil springs are fitted.
They should be red and you should have a total of 9. If you have 12 you have a unit built for a larger tractor.
If the coils are binding you will either need to decrease the PTO plate clearance slightly or fit a set (or two) of shims between the clutch unit and flywheel. One set was fitted as standard to most 11" clutch units. We have had to fit additional set to obtain correct movement in the past. The last part number that I have is 828 039M1 Spacer (set of 3) You have not mentioned these spacers (shims) so were they fitted originally, have you left them out?
First of all observe the operation then please come back if I can help you any more.
Regards
DavidP
Bob Pete
01-29-2007 21:41:05
 Re: Massey Ferguson 65 in reply to DavidP, South Wales, 01-29-2007 01:35:13
Hi David,
No, I never adjusted the lever screws, (I assume these are the screws on the release levers). I just checked to see that they all made contact evenly.
I don't have the tractor where I can check things right now----but I believe the clutch has 12 springs. There were no shims just the air ring between the clutch and the flywheel. The clutch had been rebuilt before and the original casting was brassed in several places when it had broken so I got a complete unit.
Will get back on the Number of springs there is.
Thanks, Bob Pete
Wyoming USA---it's cold here--down to 0 degrees F every night.
