Gary_N_WV
Aaron Ford
02-05-2007 18:08:29
Hey Gary, I found your fuel filter assembly, both housings and filters all ready assembled, for $42 at stephens. I thought I would mention that if you have not found it yet. Later,
Let's go Mountaineers,
Aaron
Gary_N_WV
02-06-2007 17:25:21
 Re: Gary_N_WV in reply to Aaron Ford, 02-05-2007 18:08:29
Thanks Aaron, but I got a new glass bowl for mine to replace the home made plastic one.
As soon as the weather gets better, I think mine will clean up and be OK.
I'm starting to recuperate from my back surgery, but these cold temperatures in my outdoor garage aren't good for tinkering with tractors.
Aaron Ford
02-06-2007 21:05:20
 Re: Gary_N_WV in reply to Gary_N_WV, 02-06-2007 17:25:21
Mine either. I set up a temporary shelter only to have it disassembled by the wind. Took it down before it got destroyed. It was nice, but I failed to tie it down properly. Fridays breeze was a killer. I torqued my back trying to replace the tarp that I had replaced the canopy with. I was out sliding in and out from under the tarp/tractor and moving snowmobiles about. When I was done, I wanted to move my wheel weights to were they would not be visible from the road. I grabbed one in one hand and two in the other. Big mistake. I can barely stand. I don't have to go to work tomorrow, but I do on Thursday. Hope to be squared away by then. Glad you got that filter straightened out. I saw the setup hanging from a display and without looking at the tag, I knew I had seen it before. Glad to hear you got yours squared away.
Aaron
