180 diesel tach drive
B. Jones
02-17-2007 15:30:46
I've found a tach drive (2758346) that fits the later model 265/275 MF tractors. Do any of you know if it will fit our older model 180 with the 236 motor. Someone once said that you could install it on these older tractors and run your tach if you used a bit longer cable. Right now our tach is run off the back of the generator. I would like to put a delco alternator on it. Thank you for any help. B. Jones
