MF 35 / ROUND BALES
CHRISMF35
02-21-2007 11:54:11
WILL A MF 35 PICK UP A ROUND BALE OF HAY?
mlauk
02-22-2007 10:26:32
 Re: MF 35 / ROUND BALES in reply to CHRISMF35, 02-21-2007 11:54:11
The 3 point on my MF 2135 will pick up a 4 x 6 bale, but the hydraulics start knocking.
Big Steve
02-22-2007 05:45:11
I have a '58 Fe35 with a modernized loader - quick release the whole nine yards. I have no problem picking up 4x5 rounds with the loader - even driving around out in the field as long as it's not too muddy and there aren't huge ruts to cross. Using the 3 pt - No issues at all lifting big rounds. These are rounds for horses - perhaps the drying affects the weight.
Jerry/MT
02-21-2007 17:49:08
What's the weight of th bales? Our 5x5 round bales with first cutting grass go 1340 lbs. Find out what the lift is rated at. My guess is around 1000-1200 lbs. My guess is that if the tractor lift is rated higher, then you'll need front ballast to keep the front wheels on the ground.
mf 148
02-21-2007 12:44:08
Hi,I used an mf 35x & mf 135 to carry round bales on the 3 point linkage rear spike with no problems.How heavy are your bales? Regards keith
mike a. tenn.
02-21-2007 15:54:00
 Re: MF 35 / ROUND BALES in reply to mf 148 , 02-21-2007 12:44:08
THAT'S the big question...how big of a bale. our 5X5 bales'll either raise the front end of the 135, or you end up brake steering. either way you aren't gonna go very far with them.
-mike
