WOBBLY WHEEL
CHRISMF35
03-05-2007 09:30:37
MY LEFT FRONT WHEEL WOBBLES. WHAT DO I NEED TO REPLACE?
MF Poor
03-05-2007 13:16:48
 Re: WOBBLY WHEEL in reply to CHRISMF35, 03-05-2007 09:30:37
Swap front wheels from side to side. See if the wobble stays with the left side or moves with the wheel. If it moves, you have a bent rim. If it stays on the left, I'd start by examining the wheel bearings first.
mike a. tenn.
03-05-2007 09:42:01
to start with, wheel bearings races and seals. also you better check your steering spindle bushings.
-mike
CHRISMF35
03-05-2007 09:51:07
 Re: WOBBLY WHEEL in reply to mike a. tenn., 03-05-2007 09:42:01
HOW DO YOU TELL IF THE SPINDLE BUSHINGS ARE WORN?
mike a. tenn.
03-05-2007 10:18:17
 Re: WOBBLY WHEEL in reply to CHRISMF35, 03-05-2007 09:51:07
jack up the tractor to take the weight off the wheels, and wiggle the wheel from top to bottom. as you watch the spindles. if there's a lot of play it's time to change them.
-mike
