180 Alternator
B. Jones
03-05-2007 16:33:33
I have been wanting to put an alternator on our old 180 diesel but I couldn't find one with a Tach Drive. I learned from this board that you can install a gear box tach drive on the front of the cam shaft. I bought one and a 10 inch longer cable and the tach works great. After that I installed a 10 si alternator. The alternator was a used one and didn't work today. Tomorrow I will take it apart and fix what ever is wrong as I used to work on them years ago and still have a lot of parts. Thank you all for the information that I received from this board. By the way I took off a 25 amp generator. We pull a sprayer part time with this tractor and the sprayer and foam marker pull 25-30 amps. With the generator we were usually 5 to 10 amps discharge.
