Massey 1150 3PNT
billybunter
03-09-2007 16:10:24
Hi
The three pnt linkage on my 1150 does not appear to lower, dont know if it lifts either as it is stuck in the high position. Any ideas? Is this a common problem. Any advice would be appreciated.
Thanks for now.
David A Brockley
03-09-2007 18:46:42
 Re: Massey 1150 3PNT in reply to billybunter, 03-09-2007 16:10:24
If I remember on the 1150 ther is a knob near the top of the rear end buy the rockshaft that can be used to lock the lift arms up. It is just a simple way to pin them up. I have had 1150 & 1155 and think both tractors have this feature.
barnrat
03-09-2007 17:20:02
Yes this can be a problems at several different levels. First the 3 point can just be stuck in place if they are used infrequently. I've had to use a bucket loader once to get the arms to go down. A more common problem especially in colder cliamates is the lift valve will stick with ice. This happed to my 1100 the other day. The other thing that can happen from infrequent 3 point use is the valve sill stick from dirt. So you haveta remove the cover below the seat and expose the oscilator and work the valve back and forth to free it up.
