hyd. problem 1080.
bill shaver
03-13-2007 13:38:14
so here it is, did my pressure checks on my hyd system aux is showing 2000 psi at 1000 rpm & multipower in low at 250 & HIGH AT 150 PSI, COULD IT BE THE SYSTEM RELIEF, OR DO YOU REPLACE THE WHOLE AUXILLARY HYD PUMP. another thing can't pick the front of the tractor off the ground, but enough strength to pick up a load of snow & ice. any ideas out there on fixing the relief , or split the tractor & replace the pump.
