444 Diesel Block
Blazing Bruck
03-15-2007 08:20:04
I have a 444 Diesel with a rod out the side. Need to know if the 277 gas block is the same as the 277 diesel block? If not, anyone have a good diesel block?
mn.Chuck
03-16-2007 20:05:57
 Re: 444 Diesel Block in reply to Blazing Bruck, 03-15-2007 08:20:04
I would be sceptical about interchanging. The part
no's are different between the gas and diesel and
even between the diesel block with APE pump and
the block with the PSB pump. Doesn't mean that
they couldn't work, but!!! Chuck
phillip d
03-16-2007 16:20:03
I have a 333Diesel,if it is like mine than i would say that it should because there is a plug in the distributor inlet where it could have also been used as a gasser.Does your block have the same as well?It is on the left on mine.phill.
