Oil Leak on MF30
Bill Hobbs
03-31-2007 12:49:20
I have a MF30 backhoe with an oil leak when the tractor is warm. The oil comes from the front of the engine, near the fan. I have been told that this Perkins engine has a "slinger" oil system and that the leak may be from too much pressure. I was told that if I clean the blow-by tube, that may help. I can't find the blow-by tube. Any help? Any other suggestions on the leak. The local dealer would be happy to change a front seal for about $1K. Ouch! Thanks for your help, I am new to this forum. Bill in New Mexico.
big dean
04-01-2007 07:47:04
 Re: Oil Leak on MF30 in reply to Bill Hobbs, 03-31-2007 12:49:20
Hi Bill the AD4-203 Perkins diesel engine used in the MF30 the gasket that goes between the top and bottom sections of the timing gear cover on the left side will push out and cause a leak there. Sometimes it will leak bad of it pushes out enough. I have a picture that shows a fix for that problem of you will email me I will email it to you.
Bill Hobbs
04-01-2007 10:53:53
 Re: Oil Leak on MF30 in reply to big dean, 04-01-2007 07:47:04
Big Dean - Thanks for the reply. I tried to e-mail you from your website but wasn't successful. Suggestions to your e-mail? Thanks again, Bill in New Mexico
