3 point lift
Bob/MS
04-03-2007 13:46:26
The hydraulic lift works sometimes and sometimes it dosen't, plenty of fluid in tractor?
Big Dean
04-03-2007 18:09:34
 Re: 3 point lift in reply to Bob/MS, 04-03-2007 13:46:26
Besides the model you have. Will your hydraulics work when the oil is cold but not after it heats up or maybe it will lift a light load but not a heavy load or is there no rime nor reason to when it will not work these things can make a big difference in where to start on diagnosing what your problem is caused by?
DavidP, South Wales
04-03-2007 14:16:34
Hi, you don't say what tractor you have or how old it is. You may have a sticking control valve in the pump due to debris or possibly the oscillator (on tractors pre 1968 or so) may be broken.
Early ones were made of aluminium, later ones steel. They are driven from the pump shaft and keep the control valve moving which in turn prevents it sticking.
DavidP.South Wales
