MF165 (AD4-203)
Bob King (Quee
04-09-2007 21:57:21
I have a 165, which is in pretty good condition, although since buying in 2005 has required some tender loving care to starter motor, power steering pump, cooling system, etc. I use it part time on 256 acre property with, post hole borer, slasher, carryall and it has a front under axle front blade with hyd lift/lower via external remotes. Recently I attempted a lift with the 3PL and found it peaked at 450kg (990 pounds). I guess I had assumed it would lift more. Can anyone suggest what it's load limit might be.
Bill Brox
04-10-2007 12:59:51
 Re: MF165 (AD4-203) in reply to Bob King (Queensland), 04-09-2007 21:57:21
1400 to 1600 kg. Different books shows different values. Also, the newer 165 with 212 engine and the wet brakes may lift as much as 1700 kg.
All this is in the lower link ball center.
TomTX
04-10-2007 03:35:53
Bob, I don't have a MF-165 Operator Manual, but I know for sure that it shuld lift WAY MORE than 990 lbs. I would guess that it would be over 2000 lbs at the ends of 3-point arms. Tom
