135 Hydraulic Oil Strainer Intake Housing
Badly Bent
04-10-2007 07:23:32
I just thought that a rebuild kit would take care of my hydraulic pump. While working on assembling the pump I found a hairline crack in my strainer housing. Well, not exactly hairline. More like broken nearly into two parts. It became broken into two parts while I was examining it. Not good.
Anybody got a spare one of these for these?
third party image
Part# 189 373 M1
Willy-N
04-17-2007 17:49:57
 Re: 135 Hydraulic Oil Strainer Intake Housing in reply to Badly Bent, 04-10-2007 07:23:32
I have one on a complete good pump. I will EMail you. Mark H.
GaryF
04-10-2007 17:54:53
BB... Where are you located? Maybe someone close to you can help Gary
Badly Bent
04-11-2007 05:16:44
 Re: 135 Hydraulic Oil Strainer Intake Housing in reply to GaryF, 04-10-2007 17:54:53
Gary, I'm located in Limestone, TN. I have found a few of them, but they are not cheap. If I had seen that crack before I ordered by rebuild kit I would have just bought another pump. We live and learn, I suppose. Tim
135 Fan
04-10-2007 14:45:17
What's it made out of? If it's pot metal you need another one. If it's aluminum a good shop specializing in aluminum could weld it up good as new. Look for a place that does snowmobiles or aluminum radiators. An aircraft specialty welding shop could also repair it to as good as new. Don't take it just anywhere because someone might say they can fix it and not have a clue. Look at some other work the shop has done. They should be able to help identify what material it's made out of. Dave
Badly Bent
04-11-2007 05:18:23
 Re: 135 Hydraulic Oil Strainer Intake Housing in reply to 135 Fan, 04-10-2007 14:45:17
Dave, Not really sure, but I think it's aluminum. Gonna check on some replacement units and see what I can come up with. Thanks for the feedback.
Tim
davediehl@hotmail.com
04-10-2007 09:14:24
I found alot of parts on the johndeere.com parts lookup. I'm amazed on how much new parts are still out there. You might try looking there for new if you can't find anything used.
Badly Bent
04-11-2007 05:18:59
 Re: 135 Hydraulic Oil Strainer Intake Housing in reply to davediehl@hotmail.com, 04-10-2007 09:14:24
Good point! I hadn't even thought about them. Tim
