MF 165 PTO wont shut off
Brian Curtin
04-21-2007 16:31:52
I have just purchased a 1970 MF 165 gas. The PTO stays on. However the pto does shut off when I turn the tractor off and start it back up again. When the tractor is running and I engage the pto it wont shut off.
I haven't opened it up yet, before I do so any ideas?
DavidP, South Wales
04-22-2007 04:43:50
 Re: MF 165 PTO wont shut off in reply to Brian Curtin, 04-21-2007 16:31:52
Hi, I assume that you have an independant PTO.
Normally the PTO not stopping is due to a worn brake pad which acts against the IPTO drum. If the drive is OK then it is unlikely to be a pump, loss of pressure problem. If you carefully press a piece of wood against the pto shaft it should stop. There is no drive. It is oil drag causing the rotation. The brake pad is not exerting enough pressure to overcome this.
The pad can be replaced through the LH side cover but it is a very difficult job. It is better to remove the hydraulic cover but do not undertake this until you have a workshop manual at the least and a suitable means of lifting the cover.
DavidP,South Wales
Bob N.Y.
04-21-2007 19:09:43
Does this tractor have Independant PTO?
