MF 65 Injector pump (Deisel pump), broken?
AndreasH
04-28-2007 06:31:09
Hi there!
Just bought an MF 65.
The owner had trouble in starting the tractor and he had dismounted the fuel feeder pump.
Wich wasn't broken, so i've reinstalled it and everything works fine, also bleeded the whole system. So i can see the deisel coming from the two bleeding bolts on the injector pump. but still there is nothing coming to the injectors, not any of them.
What can it be?, is the injector pump gone?
Thankyou for ideas!
regards
Andreas
Massey 65
05-23-2007 13:56:54
 Re: MF 65 Injector pump (Deisel pump), broken? in reply to AndreasH, 04-28-2007 06:31:09
A little tip ill probably sound a fool for suggesting the obvious thing. Yet u do realise when u loosen the injectors u have to turn the engine over till the diesel leaks out because the hand pump doesnt deliver the fuel past the injector pump. Dont let her start just jun her over till the injector puts out diesel
AndeasH
05-05-2007 12:58:00
Not sure it was the injectorpump, since the new one i bought gave me the same problem.
And this pump was working, for sure i know.
This drives me crasy and i have no ideas left.
Ronald Eisenhardt
05-02-2007 19:52:49
I had similar problem and it was the injector pump also. It was the metering valve that went bad it cost me over $700 to have it rebuilt. I just finished installing it and now everything on my MF65 is just fine.
AndreasH
05-02-2007 22:27:06
 Re: MF 65 Injector pump (Deisel pump), broken? in reply to Ronald Eisenhardt, 05-02-2007 19:52:49
Hi there,
yes, i thought so as well. So i've bought an new replacement pump wich cost me about 250$.
Hopefully it will work now.. hehe.
Thanx!
/Andreas
TomTX
04-29-2007 05:40:11
Follow the procedures in your Operator Manual. My model is different, but call for loosening each line at the injectors one at a time until fuel leaks out. Tom
AndreasH
04-29-2007 08:25:11
 Re: MF 65 Injector pump (Deisel pump), broken? in reply to TomTX, 04-29-2007 05:40:11
Hi Tom!
I have already tried, but no fuel comes to the injectors.
And i found out today that the injectorpump is broken :(.
/Andreas
