MF 165 Tech
Bill c
05-01-2007 19:11:46
Hi, Anyone know how to get the tech apart to tighten the 2 screws on the indicator which have come loose. Thanks Bill
Don-Wi
05-01-2007 23:26:00
 Re: MF 165 Tech in reply to Bill c, 05-01-2007 19:11:46
You mean the tach? I just took one apart last night for our 285. The chrome trim ring is crimped on, you need to remove this and all the guts will come out after removing the screws that hold it to the back of the shell. I found a side cutting pliers worked the best for un-crimpiong it, then to re-crimp it back on later I used a GOOD pliers that has a flat, square nose that both jaws still lined up. I used that to start to fold it back over then once it was foled over I went all the way arounf it with the pliers and squeezed as hard as I could. You can definatley tell someone was inside it, but it was either that to replace a busted stud on the back cup, or $150 for a new tach that doesn't look original...
This is assuming it's similar in construction as the 285's tach. It may very well be different because of the neon lights.
Donovan from Wisconsin
