MH30 Rear PTO, Play
Abe
09-25-2000 11:18:54
My mh30 1949 has a side pulley and rear PTO
and my MH30 1951 has the rear PTO and a dust cap
covering side pulley shaft.
My 1951 rear PTO shaft shows a 3/8 in front/back
(in/out) play. But my 1949 is dead solid, no play at all.
Is this due to the 51 missing pulley, thereby
allowing more gear lash, or do I have something
to worry about.
I'm using the 49 for scrap and building the 51.
The PTO works fine but don't want to use it under
load til i know its safe. I am trying to avoid the work of taking off the trans plates of both to see the difference.
Does anyone have any ideas.
Abe
10-03-2000 16:57:34
 Re: MH30 Rear PTO, Play in reply to Abe, 09-25-2000 11:18:54
Got the answer folks.
I finally got the guts to take off the gear
case cover. As it turns out the pto shaft is in
2 parts, front and back. The back part is simply
a splined sleeve with a cotter pin that fits on
the front shaft. The back part extends out the
rear of the tractor. I discovered it was just
the sleeve that had the play in it. The front
(most important) part is rock solid.
Thanks for everything.
Thyge
09-26-2000 11:07:33
Is the thrust bearing seated and locked correctly?
Frog Level
09-25-2000 13:21:26
My 49 MH 30 has the belt pulley and there is no end play in the PTO, for what that's worth. You don't happen to have an original 6V generator you'd like to part with, do you?
