Intermittent rough idle
Bart CA
05-16-2007 09:30:05
Hi
I use a MF-50 Z-134 When the idle is rough it produces a bad exhaust smell which is very uncomfortable.
When idle is rough I adjust the idle mixture screw for higher idle it runs smooth and no bad exhaust smell... after 15-20 minuted rough idle returns I have to readjust the idle mixture screw again 15-20 minutes again and again.
The screw is well retained by the spring and do not turn by itself...gas is new...sediment bowl & filter are new...new points/condenser/plugs new cap/rotor carburetor drained several times by the drain plug under carb...new vented gas cap...air filter cleaned and new oil....
compression 120 PSI ±8 PSI among the 4.
What do you think ?
Thanks in advance
Bart CA
supergrumpy
05-17-2007 09:15:25
 Re: Intermittent rough idle in reply to Bart CA, 05-16-2007 09:30:05
never had your exact problem but if I did, I would replace needle/seat in carb and make sure the float was gas-tight and properly adjusted
if you try this please let me know the results
