MF 236 LOADER BRACKETS
anubis
05-17-2007 14:28:34
Hello wondering if anyone out there has mf 236 loader on any of the following tractors: MF 165,175 or early model mf 255,265,275 with single cylinder steering(without cab).
I am trying to fabricate the front mounting brackets to fit my MF236 loader on my MF165. All the above models should be the same. I need measurments and angles of the front mounting brackets.
The brackets i have came off a MF283 and won"t work on my tractor. I would appreciate any help. Thanks!
Case450
05-18-2007 17:24:51
 Re: MF 236 LOADER BRACKETS in reply to anubis, 05-17-2007 14:28:34
Is it not possible to get specs from a dealer? For the angle info yourlooking for?
Anubis
05-18-2007 17:39:22
 Re: MF 236 LOADER BRACKETS in reply to Case450, 05-18-2007 17:24:51
i had my local dealer print off all the info they had from Massey and it did not include specs, just part #s from everything on the loader.
Bret G
05-17-2007 23:12:21
this fit right in with a question i have. ( i don' mean to barge in and take over) I have a 67 MF 180, I would really like to put a loader on this tractor. I can see where to mount the front mounts of the loader, but what about the rear mounts?? can i use the four bolts on the bottom of the bell housing area to bolt a cross beam to? Also, does the remote cylinder hydrauilc pump produce enough flow to run a loader? Is there power beyond ports on the stock remote hyd. valve?
any help would be greatly appreciated!
